aeroquip, cvh motorsport rocker zvh plate
right i have got a few bits i could do with clearing to free up some funds to finish the fiesta off....
will keep adding bits as and when i find them but here's the list for now.
Aeroquip -6PTFE fuel hose
2 x 2.5mtr lengths (5mtrs total) of aeroquip -6 PTFE lined fuel hose, forgot i had a 2.5 mtr length and then brought 6 mtrs from thinkauto to do through the car at £10 per mtr!!!
This hose is high pressure and the correct bore for both feed and return and being PTFE lined will not breath vapor into the car. this is more than enough to do front to back of a fiesta or escort!!!!
am looking for £25 plus postage.
genuine ford CVH motorsport alloy rocker cover with correct oil filler cap.
Great condition as origionally fitted to the RS1600i free from cracks or warping and comes with the correct filler cap for the oi which is very hard to come hold of as they have been lost or broken.
Has had the vacume for the carb blocked with weld and then the 1/2" push fit breathers changed for -8 aeroquip weld on fittins to run aeroqip hose.
Am after £65 plus postage.
ZVH water pump adaptor plate
ZVH waterpump adaptor plate to run a CVH water pump on a zetec bottom end complete with gasket, never used.
£10 posted!
£10 posted!
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
DavidK
Sep 27, 2015 02:55 PM
