Focus 1.6 Ztec SE Crank Pulley Totque Setting
Old Apr 20, 2009 | 05:06 PM
delishere's Avatar
delishere
Default Focus 1.6 Ztec SE Crank Pulley Totque Setting
After using wrong torque setting for crank shaft pulley twice!! Yes a right pain in time and cash. Does anyone know the torque setting for the crank pulley on this engine. It must be tight as no woodruff key just free floating pulley.
Cheers DelBoy
Old Apr 22, 2009 | 08:01 PM
mercury grey minter's Avatar
mercury grey minter
Done mine today,a bit fiddly as you said (no wood ruff key)
115NM,same torque setting as the wheel nuts.
Don,t do what i did and forget to put the small crankshaft cover on before the pulley.I hope you used a new 18mm bolt.
Old Apr 27, 2009 | 12:58 PM
appytizer's Avatar
appytizer
Say's in Haynes manual 40nm then angle tighten 90 degrees.
Got to do my cam belt on the 1.6 se. So could you tell me how you guys locked the crank when you undid the crank bolt
Old Apr 27, 2009 | 01:03 PM
OldDan's Avatar
OldDan
http://www.toolmix.com/browse/produc...s52r=FROOGLEUK
I think the ones you using to find TDC will bend - that looks a specific tool for locking it though.
Old Apr 27, 2009 | 01:09 PM
appytizer's Avatar
appytizer
yes your right OldDan, thats for setting TDC. I was wondering if they jammed the flywheel or something whilst they undid the crank bolt.
Old Apr 27, 2009 | 01:11 PM
OldDan's Avatar
OldDan
I use a gun usually never undone one with a bar..
Old Apr 28, 2009 | 09:33 PM
mercury grey minter
Starter motor out and lock the flywheel with a screw driver,you will need some one to hold the screwdriver.I used the AUTODATER TIMING BELT BOOK and it says in there 115nm and a new crankshaft pulley bolt will be needed.
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
JoeyBoyden
14
Aug 15, 2015 09:51 PM
