zvh alternator bracket help
Right peeps im stumped finally got my zvh in yesterday built it all up, and then hit a snag which i cant find any info on anywhere.
The front alternator mount bolts up and i then placed the alternator bolt in the bottom and alls fine. when to put the top alternator bracket on, the one you adjust the tension on the belt on and theres nowhere in the block to bolt it, does the s2 one bolt in the block as well as i cant find any info anywhere where you have to drill the zetec for the arm
jonfoc
16
Sep 11, 2018 05:35 PM
