fuelling
Old Apr 18, 2009 | 12:01 PM
raycov's Avatar
raycov
Default fuelling
why has my car started to stall.it is fine when you fire it up but when you go to pull away it cuts out,and wont start again for a minute or so ,i am getting a good spark so how do you check the fuelling if that is the problem or what do people think it could be.
cheers
Old Apr 18, 2009 | 01:59 PM
sean_rsts2's Avatar
sean_rsts2
addicted to boost
i have sort of the same problem, my car starts fine most times, but every so often it starts and dies out straight away. seems to do it most when i have bin to fill up at petrol station. i dont think its anything to do with fueling as my car is set up spot on fueling wise. it just seems to flood itself!
Old Apr 18, 2009 | 02:17 PM
Dragsteer's Avatar
Dragsteer
to check fueling you will need wide band labmda. also you can check mixure at idle, it can affect starting.
The Sludge
Technical essay Archives
28
Dec 30, 2008 09:00 PM
haz87
Oct 24, 2005 04:37 PM
s2_rsturbo
Dec 18, 2004 12:13 PM
