wheres the coolant fan relay located on the saph?
Old Apr 11, 2009 | 05:01 PM
spoilt_rs's Avatar
spoilt_rs
Default wheres the coolant fan relay located on the saph?
cheers
Old Apr 11, 2009 | 07:10 PM
In the fusebox, near the wiper motor/heater fan.
You can usually recognise which one it is as it will be melted!!, along with the fuseholder fo it.
Old Apr 11, 2009 | 08:38 PM
Toe Knee's Avatar
Toe Knee
u on about the relay or fuse tabs as its normally the fuse that melts?!
Old Apr 11, 2009 | 09:29 PM
As tabetha said its in the fuse box.
Old Apr 12, 2009 | 10:16 AM
On mine the fuseholder was melted so bad you couldn't actually get a fuse in the slot, and the relay terminals also showed signs of getting way too hot, but of course first thing was rewire anyway, best thing.
Old Apr 12, 2009 | 10:41 AM
nicksaph's Avatar
nicksaph
relay for the cooling fans is XI (or no, 11 if you don't speak roman numaerals) in the sierra user manual it is listed as being for the engine management but that is for non cosworth varients
cheeRS nick
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
mjonathan24
Oct 29, 2015 10:39 PM
Rsmat
89
Oct 12, 2015 07:50 AM
Russ Payne
Sep 25, 2015 08:29 PM
