How hard to drill through a turbo exhaust housing?
General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
after thinking about putting my EGT in the downpipe it will just be better to put it in the husing and tapping it were the manifold goes on like Porkies old 3door.
how hard is the material compared to a stainless exhaust for instance?
im using a hand drill not a pillar!
They worked perfect for me when I drilled out cozmeisters rounded head bolt, bit too bloody sharp to be honest kept trying to drag into work piece as I was drilling having to hold them back!!
i had to drill a housing once, and the cobolt drill took 2 hours to go through. took it to an engineering shop and they said it had become hardened due to the heat.
