Boot floor
Has anyone on here had to weld their boot floor, where the chassis rails run underneith?
I had a good poke at mine today and poked a hole about 1"wide by about 4" long. The rest seems solid.
Hope its not destined for the scrap heap!
The rest seems ok. Battery tray etc. seem fine. The car has had a lot of work in the past. New sills, doors, wings etc. Looking under the car it seems it has been under sealed all the way back to in front of the rear axle.
Ive just been and had a GOOD poke around under the car and it all seems good. Panic over. It is 21 years old I suppose. Ill get it repaired and underseal the back end and wax oil all the chassis rails. That should see it right for a bit. Its only a stop gap as next summer ill be selling it for a saphire cossie fingers crossed.
don't panic a welder is an old fords best friend
easily sorted and it's all out of the way, so you could even put of painting it in the right colour if you were a little strapped.
Orion_Gav
Sep 29, 2015 04:50 PM
