Chip question
Old Apr 10, 2009 | 02:16 PM
B_E_N's Avatar
B_E_N
Default Chip question
rite seen as am rebuilding my engine, block and head are gettin a full recon, my car has been chipped, but that shouldn;t effect it wen i rebuild agen shud it? the chips in the ecu i believe? its also on a switch, wen off its 5 psi which is near enuff standard?? do i just run it like that until its run in, say 1000 miles? thanks ben
Old Apr 10, 2009 | 07:17 PM
mark2's Avatar
mark2
once the engine is back in just get it running safely and then to a tuner to get things checked and adjusted as you dont want it over fueling and getting bore wash ,keep revs low 2k /2.5k max
what you got to remember once built it is theory a new engine running on a setup from a different engine if you follow
tell tuner its freshly built and needs setting for running in
i have built a couple of turbo engines and when i have put them back in the same car they have always been adjusted on the co2
old engines needing rebuilds will have carbon deposits with affects the flow of things , new engines breath different to old
mark2
Old Apr 13, 2009 | 06:57 AM
B_E_N's Avatar
B_E_N
thanks alot mate!
tankybaby66
Feb 6, 2016 02:24 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
stevecfrst1
Sep 30, 2015 05:18 AM
