Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
Mondeo Zetec
Old Apr 10, 2009 | 01:30 PM
emcki05's Avatar
emcki05
Question Mondeo Zetec
Hello all, first post on here, looks a great site
been racin mondeos now for a while and want to spend abit of money on an engine for racing, i run with carbs on them,
whats the best way to go about getting some more horse power out of them? cams?which ones? what else would help
cheers
Old Apr 10, 2009 | 03:14 PM
Do you mean carbs as in carbs, or tb's, which for some odd reason some call bike carbs!!
If it is carbs, then headwork would be needed for serious power, what are you doing about the ignition side as this is just as important as the fuelling that it has the correct ignition curve.
Old Apr 10, 2009 | 03:38 PM
emcki05's Avatar
emcki05
yes proper carbs!
weber 38 dgas with air filter
we run the early mk1 mondeo wiring looms to answer your question
will need some head work such as? skimming? what else?
cheers for reply
Old Apr 11, 2009 | 10:10 AM
I would go with a 40DFI carb, lots of porting work, good skim high comp pistons, lighten balance, you could put in some decent cams, but all this is a total waste of time if using a standard ignition curve, you will just be using lots of petrol to not get very far.
It at the very least needs adjustable igntion.
Old Oct 6, 2009 | 02:41 PM
emcki05's Avatar
emcki05
can you explain more ont he adjustable ignition?whats an example of one?
thanks
mk3ste
Oct 17, 2021 10:09 AM
wowk
Mar 30, 2021 07:49 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
The Enigma
Sep 29, 2015 10:31 AM
