87 rst spotlight specs
Old Apr 9, 2009 | 08:55 PM
gtdjon's Avatar
gtdjon
Default 87 rst spotlight specs
I have a 1987 rst and rather than turn it 90 spec i want to complete its look by fitting the optional spotlights to the bumper.
Im after some pictures and info on there way of mounting and place and also on where the switch and what the switch is like on the dash.
I want it to look factory standard.
thank you very much
Old Apr 10, 2009 | 05:41 AM
philyS2's Avatar
philyS2
The spots dont have a switch mate,they shud come on when you put your full beam on
Old Apr 10, 2009 | 07:42 AM
rickbartlett's Avatar
rickbartlett
G911 TTA
as said,they will come on with full beam,the wiring plugs will be there around the front panel area and the brackets bolt to the front panel and poke out of where the grill bit is in the bumper.
Old Apr 10, 2009 | 10:23 AM
gtdjon's Avatar
gtdjon
thanks very much guys
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
stevecfrst1
Sep 30, 2015 05:18 AM
