S2 engine mount rubber... where?
This may be a very simple question to answer, but i have given up searching now.
I'm in need of a new engine mount rubber set. Only the rubber bits tho as the mount is a modified version for my ZVH.
I cant do with the stupid squeak it gives off now!
Where can i get some from please.
https://www.burtonpower.com/product_main.aspx?home.aspx
But comes with the steel part to, supose you could always flog that bit!
im sure ive heard mention in the past of uprated poly versions, and id assume they would definitely come with just the rubber part
might be worth a bit of research, as for 40quid, u either get a standard rubber mount and then an odd engine mount shaped steel paperweight, or possibly an uprated rubber and no left over shite lol
oh and whatever you do, have fun fitting the rubber back in the mount, mine was a right slag!!
track.focus'd
Aug 12, 2015 05:53 PM
lockie
Jul 31, 2015 10:03 PM
