Idle screw Cosworth
Old Apr 8, 2009 | 04:03 PM
Cossy Mike's Avatar
Cossy Mike
Default Idle screw Cosworth
Sounds easy enough but,
my cossie is trying to idle at 600rpm and obviously eventually cuts out. Can someone tell me or post a quick pis of the location to the idle screw please?
I need to just tweak it a little bit,
thanks
Old Apr 8, 2009 | 05:46 PM
Alvyn's Avatar
Alvyn
bottom of the throttle body IF it's a 2wd then it has a lock nut that need undoing and then a flat screw driver to adjust the bolt IF a 4x4 then it's just the screw driver needed BUT I BET it will be locked solid and you may have to take the body off and free it up!
Old Apr 8, 2009 | 06:40 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
directly in the center line of the t/b, under the boost hose...
you can adjust it with the boost hose removed to make it easy
its a brass flathead on the 4x4, about 10mm in diameter.
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
muffster
13
Sep 3, 2015 09:40 PM
Sheepdisease
Aug 30, 2015 09:11 PM
Aug 14, 2015 07:29 AM
