cosworth fueling
Old Apr 7, 2009 | 10:29 PM
ali24v4x4cosworthvan's Avatar
Default cosworth fueling
i've just fitted a stage 3 2wd cosworth engine into my mk2 escort, usual spec, 3bar,-31, greens, t34.
i've got the boost set a 1bar at the moment, what i want to know is if i wind up the boost will the fuelling sort itself when ecu senses the extra pressure? also if i get a mot station to carry out a emissions test what should the readings be?
Old Apr 8, 2009 | 03:20 PM
cos i want 2be's Avatar
cos i want 2be
what chip spec is it your runin?should get it setup on a rolling road and then you no what happen when bein run
Old Apr 8, 2009 | 03:59 PM
its a stage 3 chip thats in the ecu, ifi remember correctly it was turbo tecnics that was printed on the top, but an not 100% sure on make!
nearest rolling road to me is about 200miles away! so was just wondering if i could check fuelling was ok another way!!!
SmudgerByName
52
Jul 28, 2016 06:14 PM
Russ Hill
Aug 31, 2015 06:44 PM
jc1989rs
Aug 30, 2015 06:32 AM
Aug 14, 2015 07:29 AM
Old ford
Jul 31, 2015 06:50 AM
