people on coilovers.advice please.
how far should the threaded rod at the top of the strut come up through the suspension tops on the front.mines seem to have came through about 50mm when i lowered the car down
??i put the top hat on underneath and no nut and then just up through the suspension top and obviously the nut at the top.should there be a nut underneath to stop it coming right through if yous get what i mean??
iv assembled mine with the top hat held with a nut, like a standard strut is built up
but yeh, mine has a lot of thread sticking through the strut cap too, does clear the bonnet though, and was told its normal, so im assuming it is
Mine aren't like that.
I have minimal thread through.
Mine go.....
Spring - Alloy Spring Retainer - Standard Bearing - Spacer Washer - Standard Top Mount - Powerflex Bush - Strut top - Nut
Hope this helps.
Mine go.....
Hope this helps.
bump.can any one confirm if a nut is meant to hold original suspension top on that you take from old suspension or is it just the one nut in the engine bay on the strut top,cheers.
cheers mate.thats good news then as i have put them on wrong.puts my mind at ease now.will get them sorted at weekend
mk3ste
Oct 17, 2021 10:09 AM
rsguy
44
Sep 29, 2015 03:29 PM
