Best clutch for EFi flywheel
I was looking for a clutch for my RST now that Bernie's Stage 2 plus is on its way. I decided to put an EFi flywheel straight away as I will switch to EFi eventually. What clutch do you suggest?
I wanted to opt for AP's CP2000-35 but it seems that the EFi flywheel is thicker and has cut outs for tps. AP recommended me not to go for their paddle clutch since I will use my RST on the road as well. I fear their normal organic might not be up to the job, if not now surely in the future. I really need suggestions...
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
