ZVH help??!!
Old Dec 2, 2004 | 03:48 PM
creedy's Avatar
creedy
Default ZVH help??!!
wot torque setting should the head bolts be??
also can i re use the head bolts they are high tenisal mild steel?
cheers
neal
Old Dec 2, 2004 | 04:32 PM
PhilM's Avatar
PhilM
PassionBMW.com Member
Id always replace headbolts.
ZVH 45ftlb, 45deg, 45deg. IMO only, use at your own risk
Old Dec 2, 2004 | 05:05 PM
creedy's Avatar
creedy
?? im lost
Old Dec 2, 2004 | 05:11 PM
Alps Pacino's Avatar
Alps Pacino
you torque all the bolts in sequence to 45ftlb then tighten them another 45 degrees (full sequence) then another 45 degrees (full sequence) if you know what i mean
Old Dec 2, 2004 | 06:31 PM
creedy's Avatar
creedy
ahhh i see says the mind man!!
thanx
Old Dec 31, 2004 | 10:42 PM
blueovalspanker's Avatar
blueovalspanker
thanx
blind man dont u mean creedy
Old Jan 2, 2005 | 09:16 PM
gavintwopies's Avatar
gavintwopies
I normally go with the settings of:
40lb/ft stg 1
60lb/ft stg 2
75lb/ft stg 3
but please bear in mind that this is with a 150mm long 12.9 rated m10 cap head bolt. i prefer to use these as they are re-usable as they are not stretch bolts but cost about the same as a stretch bolts
they normally cost about 12 quid a set up here in the north-east 1.50 a bolt
mk1turboestate
Dec 2, 2015 08:31 PM
Chas
Oct 5, 2015 07:13 PM
davidfordrs
Sep 23, 2015 02:26 PM
davidfordrs
Sep 21, 2015 04:23 AM
Del gsxr
Sep 19, 2015 05:53 PM
