engine prob..anyone help
Old Apr 2, 2009 | 11:58 AM
kurdt5's Avatar
kurdt5
Default engine prob..anyone help
broke down and determeined the metering unit had gone...replaced with a spare...but car was running rich and not ideling with the replacement on...
took to the garage to get the timing, fueling done ect.
picked up the car just now but it wont idle...timing is done and fuelling. The car starts ok but cuts out unless you keep your foot on the pedal.....garage doesnt know what the problem is.
any ideas??
This is on a Series 1 Rs Turbo
Old Apr 2, 2009 | 12:38 PM
Karlos G's Avatar
Karlos G
Balls Deep!
If it drives ok other than this problem then it sounds like the idle is low or lean, or you have an air leak.
Old Apr 2, 2009 | 01:05 PM
orion88's Avatar
orion88
first thoughtsa are air leak tbh
Old Apr 2, 2009 | 01:10 PM
cjwilliams05's Avatar
cjwilliams05
I had a similar thing turned out to be an air leak.
Old Apr 2, 2009 | 01:29 PM
kurdt5's Avatar
kurdt5
just removed and tightened all my pipes but still does the same thing.
Old Apr 2, 2009 | 06:48 PM
RabReith89's Avatar
RabReith89
This happend to me and a hose for my rad was burst so i cut it and then put it bk on then it was fine
Old Apr 3, 2009 | 09:52 AM
lurch1977's Avatar
lurch1977
Had the same issue on mine recently turned out it was the cam
Old Apr 3, 2009 | 04:57 PM
kurdt5's Avatar
kurdt5
Well scouted around the car this morning ready to dismantle bits and found the fuel banjo that goes to the fuel filter was missing a copper o ring.........luckily i brought a spare set on ebay last year so thats done the job.
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
