RS Turbo metering unit air flow sensor
Old Mar 28, 2009 | 12:26 PM
tiff_lee's Avatar
tiff_lee
Default RS Turbo metering unit air flow sensor
On the side of the metering unit there is a 3 pin connection for the airflow/metering flap sensor, however my loom no longer has the original 3 pin plug and only 3 individually crimped wires, brown, brown/yellow and brown/green.
Could anyone please tell me the correct order these connect to the sensor from top to bottom or vice versa as you look down on the
unit.
thanks, Lee
andy130
Mar 15, 2016 07:59 AM
