Flywheel MFi to EFi
I was thinking about buying a 220mm steel flywheel from Burton. But on their site it says that it's no good for EFi. Is there any other option that will work with both MFi and EFi and fit with the AP Racing extra high torque organic clutch as I plan to switch to EFi in the future?
Also, do you know the part number of the bolts from the clutch to the flywheel, and how many will I need? As I can't find them on the Burton site. I only managed to find the flywheel bolts.
Why not just use an OEM EFi flywheel? It will work on an MFi setup and also when you change over to EFi, remembering of course that you need the sensor in the block too, to read the pulses, when it comes to the conversion to EFi.
