cossie management
Old Mar 25, 2009 | 06:14 PM
martinmilne's Avatar
martinmilne
Default cossie management
i have a frst engine fitted in my escort it has 195 chip bieges and t3 escort and of course the efi management so how much would it cost to convert and wat is needed i ve heard before that oddkidd does it 1200 fitted but as i already have the efi manifold and everything will it be cheaper?
and is it worth it ?
Old Mar 25, 2009 | 07:50 PM
fatmike's Avatar
fatmike
u need to speek to jano at oddkidd mate but the cosworth management is defo
beter
Old Mar 25, 2009 | 07:54 PM
grsford's Avatar
grsford
you have only have a couple of parts that are needed for cosworth managment when running frst stuff, inlets wrong throttle body is wrong loom ecu injectors idle valve sensors pickups well best part all of it tbh and if jano has quoted you for the conversion fitted then that would be the way to go
cosworth managment was the best mod i ever made on my car
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
griffo69
Oct 4, 2015 11:58 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
deathrider666
Sep 28, 2015 06:12 PM
