Escort Cosworth and 18" Rondells
Old Dec 1, 2004 | 06:06 PM
Malc50's Avatar
Malc50
Default Escort Cosworth and 18" Rondells
Hi
Can anyone tell me what I need to do to get 18" Rondells to fit on my Escort Cosworth with Koni shocks. Also does fitting 18's put the speedo out by much, if so how much?????
Thks for ya help...
Malc
Old Dec 1, 2004 | 06:10 PM
Mr RS500's Avatar
Mr RS500
The rondells will go on with no mods at all
Not shure about the speedo issue tho ,, Wont be a lot out tho
Old Dec 1, 2004 | 06:12 PM
Rs Craig's Avatar
Rs Craig
land of the rising sun
From: sheffield,home of james toseland world superbike champion
all you need to do is mod the spring platforms with either the welder or a hammer.You need to put a flat spot on the bottom of the cup where the wheel fits so it can turn mine was welded but we modded my m8's with a hammer easy really... hope this helps....
Old Dec 1, 2004 | 06:21 PM
Mr RS500's Avatar
Mr RS500
Craig ,,
I dont understand ,,,,,,,,, mine went on with no trubble with the spring cups
Old Dec 1, 2004 | 06:46 PM
AJ Escos's Avatar
AJ Escos
spring cups are different on the later small turbo cars it should only be these cars that need the spring cup modifying
Old Dec 1, 2004 | 06:51 PM
Mr RS500's Avatar
Mr RS500
Well you learn summat everyday
Old Dec 1, 2004 | 06:56 PM
SteveB's Avatar
SteveB
Konis now come with the modded spring cup std... so it depends on the age of the 1's you have
Old Dec 1, 2004 | 07:01 PM
Kevin Sharp's Avatar
Kevin Sharp
with my rondells with 245/40/18, when my speedo was showing 145 mph it was actually doing 155mph,that was with redlines datron timing gear i never thought i,d see a ford speedo reading slow
Old Dec 1, 2004 | 07:05 PM
Mr RS500's Avatar
Mr RS500
Thats just because yours cant keep up Kev
Old Dec 1, 2004 | 07:09 PM
Kevin Sharp
lol...i hadnt thought of that!
Rs Craig's Avatar
Rs Craig
it all depends on what offset they are if there the et 25 offset you do have to mod if there et 18 they go straight on but what do i no
Old Dec 1, 2004 | 07:27 PM
Holty's Avatar
Holty
The tyre profile has something to do with it too, 225/35 bolt straight on 225/40 need koni shocks modded..... just done it to mine
Old Dec 1, 2004 | 07:32 PM
dave green's Avatar
dave green
You will find the speedo is more accurate with 18s on than it is with standard wheels.
Old Dec 1, 2004 | 07:40 PM
ESCYSCOTT's Avatar
ESCYSCOTT
put bilstiens on and you wont have any catching probs at all
Old Dec 1, 2004 | 07:46 PM
Malc50's Avatar
Malc50
Hi,
Thanks for the input, unfortunately my koni's were put on in 97 so it seems they will need modding. I take it this involves taking all four corners off , modding them and then refitting....why is nothing ever simple
Cheers Malc
Old Dec 1, 2004 | 08:15 PM
Rs Craig's Avatar
Rs Craig
it is simple bash with soft hammer on front konis where wheel catches
Old Dec 1, 2004 | 09:08 PM
Chris Reade's Avatar
Chris Reade
My own car Small Turbo, fitted Koni's and Rondell's with 225/40 tyres 4 years ago and had no problems. However a friend at the same time who fitted his with 235/40 tyres did have to mod his front Koni's.
I would try first and see what gap you have with the tyres you are going to use as in my experiance tyre profile did make a difference.
Vincereese
Jun 1, 2023 09:14 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
