Saph boot, water inside
Old Dec 1, 2004 | 01:05 PM
EssexBoyRacer's Avatar
EssexBoyRacer
Default Saph boot, water inside
Opened the boot on the saph the other day and a shit load of rain water poured out from inside the boot lid.
Is that normal? Was even comming out the latch bit.
Old Dec 1, 2004 | 01:06 PM
DOO's Avatar
DOO
rear lamp gsk worth checking
Old Dec 1, 2004 | 01:08 PM
EssexBoyRacer
lamp gasket? but the lamps are lower than the bootlid?
Old Dec 1, 2004 | 01:12 PM
Martyn's Avatar
Martyn
Must be the bootlid seal then. Is the boot carpet wet too?
I need to reseal my rear lights as they are letting in water
Old Dec 1, 2004 | 01:14 PM
EssexBoyRacer
nah the boot was bone dry, when I opened the boot all the water came running out the bootlid.
Old Dec 1, 2004 | 01:15 PM
Sticky.'s Avatar
Sticky.
It's your rear spoiler mate
Mine does it on the left side (passenger), its coming through the spoiler
When you open the boot, the inside top of teh boot is damp & full of condensation
Old Dec 1, 2004 | 01:17 PM
EssexBoyRacer
fook! take it its not an easy job to seal up?
Old Dec 1, 2004 | 01:20 PM
Sticky.'s Avatar
Sticky.
Lights are easy to do, boot seal is easy to do........
But the boot spoiler, just make sure you have someone to help you, as the boot will spring open, & expect the unexpected when taking the spoiler off
Old Dec 1, 2004 | 01:22 PM
EssexBoyRacer
great.
Old Dec 1, 2004 | 01:24 PM
Sticky.'s Avatar
Sticky.
Sorry mate
Old Dec 1, 2004 | 01:51 PM
JamesH's Avatar
JamesH
Old Dec 1, 2004 | 02:59 PM
Paddy's Avatar
Paddy
Legend
I know this aint the best thing, specially if your going to paint anywhere near it in the future, but silicone bathroom sealant [clear stuff] will seal it a treat
Old Dec 1, 2004 | 04:08 PM
EssexBoyRacer
probably a good idea pad, if I ever had to repair the boot I'd get another one n e way.
Old Dec 1, 2004 | 05:10 PM
CosKev3's Avatar
CosKev3
Check your drainage holes are clear on bottom lip of boot lid
Even with water leaking in round spoiler it should drain threw these holes
Seems strange but both saph's I've owned have had only 1 of the drain holes clear,
there are 3 or 5 holes there but only 1 clear
Drill the others out and give a good coat of wax-oil from the inside
Old Dec 1, 2004 | 09:32 PM
EssexBoyRacer
Cheers fella I will look into this.
155lee
Oct 27, 2015 04:55 AM
A.t.p
Sep 29, 2015 05:04 PM
rsguy
44
Sep 29, 2015 03:29 PM
Russ Payne
Sep 25, 2015 08:29 PM
