fitting oil breather tank... '''help'''
Old Mar 21, 2009 | 12:57 PM
RSTurboSI's Avatar
RSTurboSI
Default fitting oil breather tank... '''help'''
right ive fitted my breather tank, oil..
BUT it wont idel right then cuts out, i removed the old brather tank, but what do i do with the hose onto of the inlet?
Old Mar 21, 2009 | 01:51 PM
studabear's Avatar
studabear
does this help, presuming you mean a bailey type kit?
with the bracket between finger and thumb of left hand connect the pipe above ur thumb to the right side of rocker the 1 at the back of breather to the left side of rocker the 1 below your thumb to the sump and the other to the metering unit or vented, if vented you will have to block the connection at the metering head
I've tried posting a picture up which someone previously posted on here
Last edited by studabear; Mar 21, 2009 at 01:58 PM. Reason: ^^^^^^^^^^^^^^^^^^^^^^^^^^^
Old Mar 21, 2009 | 02:14 PM
RSTurboSI's Avatar
RSTurboSI
this image here, shows where i have blanked ontop of the inlet
Old Mar 21, 2009 | 02:18 PM
RSTurboSI's Avatar
RSTurboSI
now i just drove the car, all ok, Untill i got it onto boost, i didnt screw down the boost hose that goes into the intercooler now its smoking, white ish smoke.. not dark...
have i blown the turbo??
RUBY123
Oct 22, 2023 12:04 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
mrmann
Aug 20, 2015 11:24 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
gingerturbo
Aug 18, 2015 07:58 PM
