My new intercooler airtec
Hi guys my airtec intercooler came today
Just need help, need to know where one or two brackets go and can u tell me if i have wired up the fan right plz cause i can start it yet till the intercooler is fitted on, thakns alot rab
Go on my profile for the pics of the fan thanks
the brackets bolt onto your front panel all you have to do is get the intercooler sitting at the correct height you want it with the brackets bolted on and get one of your mates to hold it in place then drill through the panel and bolt it on easy peasy!!
as for wiring the fans you wont know until you start the car and see if they are wired correctly they will suck or blow then take it from there
did you get the instruction leaflet with the cooler mate as i just bought and fitted one of these and i got the instructions and it was a doddle to fit!!!
Yea mate i got them we the intercooler, just there are 4 brackets that come as you know, 2 that go on each side and theres a L shaped one for the bottom and a bigger one whit like a bullets coming out of it for the top. I know where the two side ones go but the top and bottom?? are they to take the whight?? have u got pics of your one mate if so it would be a grate help thanks.
Got every thing workin fine mate , What a diffrance it makes
One problem tho ma rad just burst had a feeling it would was in a bad way, No worrys tho just bought the alloy rad from them two.
Russ Payne
Sep 25, 2015 08:29 PM
