Do you get many problems with Escort Cosworth's?
Old Nov 30, 2004 | 08:03 PM
chunny's Avatar
chunny
Default Do you get many problems with Escort Cosworth's?
.....as the wife is starting to have doubts because of there age!!
Old Nov 30, 2004 | 08:04 PM
The Sludge's Avatar
The Sludge
garibaldi
good question cos i am in the market for buying one in the new year
Old Nov 30, 2004 | 08:06 PM
Glenn5's Avatar
Glenn5
no only you cant park them anywhere
Old Nov 30, 2004 | 08:07 PM
Billabong's Avatar
Billabong
Usual suspects:
Wiring loom can give issues
Fusebox
Main loom plugs under bonnet vent
Front bushes are crap, leads to erratic handling & poor tyre wear
Some P8 ECU's suffer form 'P8 syndrome'
Most of the above common problems would have been fixed by any caring owners Other than that, they generally fair better than other 'normal' escorts of similar age, as they are usually looked after. But as with any car, do all the checking you can etc, as some can afford to buy them, but not run and care for them properly....
Old Nov 30, 2004 | 08:20 PM
Fozy's Avatar
Fozy
as billiabong. If it has the receipts and the work is completed properly, then the car will treat you well.
Old Nov 30, 2004 | 08:26 PM
dave green's Avatar
dave green
As billabong buy from a careing owner, Ive had mine over four years, no problems other than self inflicked ones.
Dave
Old Nov 30, 2004 | 08:35 PM
furry's Avatar
furry
DECODING JIBBA JABBA!!
no more than any other rs, i'd say. defo no rot problems
Old Nov 30, 2004 | 08:40 PM
apples24's Avatar
apples24
well apart from destroying geaboxes, throwing diffs, melting pistons, thowing rods, headgaskets, rust, silly electrical faults and eating tyres etc there actually quite good
Old Nov 30, 2004 | 09:28 PM
Gaaables's Avatar
Gaaables
lol @ apples, no problems with mine yet
Old Nov 30, 2004 | 09:31 PM
Azrael's Avatar
Azrael
If you can get a good one probably no bigger problems.. if not... well I could write a book :-((((
Old Nov 30, 2004 | 11:41 PM
Rs Baz's Avatar
Rs Baz
pmsl @ apples {only if you drive them hard} i take it
Old Dec 1, 2004 | 07:42 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
If properly modified - none more than any other car.
Vincereese
Jun 1, 2023 09:14 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
