1994 mkV escort + MOT advisory
Hi All,
I have the following advisory notes from my MOT and wondered if anybody could please tell me if the parts are readily available, where I can get them and how difficult it would be to fix these myself.
007 Nearside front lower suspension arm rubber bush deteriorated but not resulting in excessive movement
008 Offside rear brake pipe slightly corroded
018 nearside rear brake binding
Thanks in advance
Thanks in advance
You'll be able to get all the stuff you need from most motor factors then its just a case of swoping them over but dont forget to bleed the brakes after youve swopped the brake pipe
