Mongoose exhaust
Hi,
Ive got a mongoose stainless on my car 2.5" bore and 3" tail pipe. My mates have told me that it sounds like its blowing, ive had the exhaust on since feb and they have only told me recently
I cant here it from inside the car, but they said that it def sounds like its blowing from outside
They work in a body repair shop and my car has been in once or twice just for minor things and they said that when it was in for undersealing recently they had a look and couldnt see anything wrong with it.
Just wondering if anyone had any ideas as to why it might sound like this? Or know of anything I could do or check?
Andrew
Andrew
I put a straight through janspeed on my mates saxo vtr the other week, sounds like it's blowing it's brains out on tickover but it's just detonation in the box that replaced the cat.
cover the tailpipe and any leaking gases u will hear, get someone to listen our for where it could be comming from as u cover the pipe.
But they also said that it def sounds like it is blowing when just setting off or driving at slowing speeds. They said if im driving fast then it sounds like any other, but if slow then it sounds like its blowing
Any help would be appreciated
check your bolts on the turbo are all tight,because mongoose has no flexi in it, it rips the bolts out the turbo
you wont hear it idling but will sound like a tractor when movin,put it under load when drivin and you should hear it loud when the revs pic up you cant hear it so much
done the same on mine only two options are gettin a flexi fitted or keep tightenin the bolts every couple of days.your choice
When you say getting a flexi fitted, does that mean a new exhaust or is there something extra that I can fit and keep the mongoose
Sorry for sounding stupid, but i dont know a great deal
it involves cuttin a bit of the exhaust close to the downpipe and welding a bit of flexi in,i need to get one fitted to mine to when i get my tubular manifold,gettin it done at AVA in glasgow
other option is to get the front section off a magnex and combine both
Havent had chance to have a look yet, need my mates to come down and show me exactly which bolts and where they are, cos as I said, i dont know a great deal, can be a bit thick when it comes to these things
tried that, my mate fell off and wont do it again, he said that he couldnt hear it leaking!!!!
Its got a lifetime guarantee and im sure that ive read someone that some people that havent been happy with the sound have taken them back. Only thing is its about a 2hour trip to where I got the exhaust and dont know if its worth it
is a newish system cus mine sounded like it was blowin, it just took ages 2 soot up properly its fine now after 2000miles i even called collins very helpfull said ride it out i will sound great when it soots up, it now pisses the neigbhours off a treat
It was put on in march brand new and Ive done nearly 3000 miles since I had it put on
Do you think that it is worth ringing the place up and seeing what they have to say?
Andrew
Andrew
