Genuin GrpA Jumbo Bilsteins Coilovers + Helper Springs SOLD
I have a pair of front GrpA Jumbo Bilsteins Coilovers + Helper Springs.
£600 no offers.
Will add pictures tomorrow.
£600 no offers.
Only spec I know at present is the springs are 32NM ?
These will fit, I should have said
They are GrpA Jumpo Bilstein Coilovers but Bodies have been converted to GrpN so they will run in 4x4 Cosworths.
Pics will be a couple of days
I am having surgary tomorrow and the springs are at the Powder Coaters.
Can I ask why you've stated "now I wona see the pic's?"
You interested or you doubt there what I've stated?
im interested how they have converted group a jumbos to std bottom round fittings, i have loads of old group a bodies, and to be honoust they are not worth a lot of money, but if they can be converted and sold on, then it might be worth it !
I dont know how they've been changed as tbh didnt know much about Billies untill I purchased a Rally Shell with these on and Marco Polo and rsjp told me what I had.
They were gong to be used on my Maxi build but there not for my needs.
hi, i'm new... £600 is a bit steap if you ask me. atm sport sell these coilovers fully refurbed for £250 each. i sold a pair last month that had recently been refurbed for £275. i would attach a picture of the ones i sold but i cant work out how to at the moment, any help would be welcome. cheers.
Hi mark
i cant tell you the bump and rebound rating or either Gravel or Tarmac
basically they are the big jumbo inserts 70mm
now the bottom platforms and the top cups that hold the springs are 100mm
The bottom platforms are magnesuim
The bodies are Gpn to fit 4wd sierra/escort road going hubs
they are a bit trick , it may be better off suited if the springs /top cups/bottom platforms were changed to 3" get more clearance from the wheel
marco
hi wot
his are totally diffent to yours mate
looking at yours ...your bodies have got the camber added at the bottom of the strut
quote=WOT;4017600]cheers, these are the ones i sold.
[IMG]i656.photobucket.com/albums/uu290/jez30/125.jpg [/IMG]
Hi mark
marco
marco
As expected, these are 50mm Recce car units , ive seen them before with Ohlins inserts as well , the base of the body is usually machined or welded off centre as the strut is way biggger than the std hub hole , nice units
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
truffleshuffle
Sep 10, 2015 09:35 PM
Adam Graham
Sep 6, 2015 06:04 AM
