breaking 2wd saph cos with 200 block engine
was bought for the running gear but a change of plans means its now for sale i have most parts still availible so just ask
complete 4x4 200 block engine in very good running condition sounds really good from cold never used any water or had any over heating problems comes with inlet manifold 2wd exhaust manifold power steering pump and bracket and alternator with bracket, will need a new bottom pully as part of its broken £1400
2wd gearbox in good conditions had no issues £300
2wd prop £70
std radiator in usable condition but not the best, has no leaks comes with fans £30
std 2wd intercooler £10
koni adjustable suspension in good condition £150
rear diff in good condition £125
rear beam with arms and hubs £100
mint condition cloth interior front seats rear bench and door cards £150
standard 2wd front 4pot calipers with pads £80
level 6 ecu with stage1 well lane chip £70
front bumper with splitter £100
lots more parts availible, regards
2wd prop £70
will take eng loom,did car drive before strip.please post pics when removed.may take calipers if i can check if they will squeeze under 13s.think someone has done it.
rob v
rob v
front calipers are sold, the engine loom i had has been converted for cvh escort/fiesta etc layout but would still fit a cosworth layout, has been cleand up and new connectors where needed also been taped up with new loom tape etc £100 or £130 with a braided coil pack conversion sub loom, regards glenn
