cooling fan idea.
Old Mar 9, 2009 | 11:09 PM
stevenebm's Avatar
stevenebm
post whore
Default cooling fan idea.
right this might be daft but i am just about to fit my front mount and alloy rad to the s1.i have them butted up tight together with on ten inch blower fan on front of cooler.my turbo is going over the gearbox so got loads of room behind radiator.would it be daft to put a 10" suction fan on the back also?as in my mind it would help with drawing the cold air that is gettin pushed through??
Old Mar 10, 2009 | 12:47 AM
rstdave's Avatar
rstdave
Wouldn't you just be dragging through the hot air that the fans on the front are drawing?? Assuming the fans on the back are no more powerfull i can't see it making any difference imo.
Old Mar 10, 2009 | 08:11 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Dont think it would hurt, but dont know if it will be better than just the front one?
Old Mar 10, 2009 | 08:24 AM
Rick's Avatar
Rick
A suction fan is 20% more efficient than a blower, so i'd try that on it's own first.
Old Mar 10, 2009 | 09:00 AM
vroomtshh's Avatar
vroomtshh
You can fit a suction fan instead, but not as well as. Unless you have enough area that the two dont block each other.
^^^^That sort of idea
Old Mar 10, 2009 | 10:31 AM
kidsRS's Avatar
kidsRS
"Ill check the stock"
Thats a new one
Old Mar 10, 2009 | 12:11 PM
stevenebm's Avatar
stevenebm
post whore
hmm just a crazy idea when i realised i had the room to do it
Old Mar 10, 2009 | 12:47 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Handy to know Rick
Old Mar 10, 2009 | 04:25 PM
stevenebm's Avatar
stevenebm
post whore
blower fan
intercooler/rad
.............suction fan
thats the sort of set up it would be like there if you take it as the blower bolted to one side of cooler and the suction fan on the opposite side.so in traffic the blower is blowing cool air through one side and the suction on the other side but not directly behind the other fan.if no ones tried it then we will never know
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
rs_jim
Oct 3, 2015 11:37 AM
simonmcf
Sep 22, 2015 08:40 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
