Rebuilding my old bottom end, how do I know what size con rod shells?
Old Mar 9, 2009 | 08:39 AM
adam.d's Avatar
adam.d
Default Rebuilding my old bottom end, how do I know what size con rod shells?
My old bottom end was BRAND NEW, totally standard size and had only done 400 miles when it eat a con rod shell I want to fix it but don't know what size shells to buy? the crank is not damaged/worn at all, neither is the con rod. Do I just buy standard size shells or do I need the next size up?
Old Mar 9, 2009 | 10:57 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
The only time you'd buy different sized shells, is when the crank has been machined, in which case the machiner should tell you what you'll need.
Old Mar 9, 2009 | 12:18 PM
adam.d's Avatar
adam.d
Second question, where the hell can I buy a set of shells from!!!!!
I've rang all the local motor factors and whoever they used to get them off no longer sells them because there all telling me there no longer made!!!
Old Mar 9, 2009 | 12:24 PM
Christian and Beccy
#1 in Spelling Club
Ford??
Burtons??
Woodforde Garage??
There's a few to be going on with.
Old Mar 9, 2009 | 12:28 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
ebay
if its eaten a shell are you sure that its not damaged the crank/conrod
if you are unsure of the state of the crank take it to a rebuilder and ask the to supply/ grind as necessary the crank
Old Mar 9, 2009 | 12:29 PM
adam.d's Avatar
adam.d
Ford don't have, nor can get any as I've tried
Burton website says there out of stock
Woodford garage website only lists a full set of mains + big ends for Ł99.95 and don't really want to pay that much
Old Mar 9, 2009 | 12:31 PM
clarke5700's Avatar
clarke5700
http://cgi.ebay.co.uk/Ford-CVH-Big-E...1%7C240%3A1318
Old Mar 9, 2009 | 12:32 PM
B16CVH's Avatar
B16CVH
I would try to figure out why it has spun a shell first otherwise you will be wasting your time replacing them.
If this has happened after just 400 miles you have a problem.
Old Mar 9, 2009 | 12:42 PM
clarke5700's Avatar
clarke5700
that to
Old Mar 9, 2009 | 12:56 PM
adam.d's Avatar
adam.d
Right, I'll tell the tale.
My RST was owned by my best mate 10 years ago, he blew the bottom end up so started to rebuild the engine. He pulled the head off and had it rebuilt. He also had the bottom end rebuilt and started to put it back in the car. He got the bottom end in and then was taken ill. He never got round to finnishing the car because he died. The car was bought from him and restored to it's former glory, hence why it stands me at an absolute fortune! but I couldn't just let the car die!!! Anyway, that's how I know the bottom end had only done 400 miles. It probably eat a shell just because it had been sat for so long, maybe ceased up or something I don't know. I replaced this bottom end with a known good 1 and kept the origional 1 "just incase". I've since had the "origional" bottom end apart and the crank is unmarked, pistons and rods are still like new so all I want is a set of shells, I'll put them in with plenty of oil on them so they move about easily and hopefully dont cease/ fall apart again.
Old Mar 9, 2009 | 12:59 PM
clarke5700's Avatar
clarke5700
are you sure the sheels are the right size for the crank then? have you mesured the crank at all? + conrods
Old Mar 9, 2009 | 01:05 PM
adam.d's Avatar
adam.d
No, I haven't measured the crank, I've just assumed it was all right as it was put together by a proper company tho. TBH, I recon it failed because it had been sat for so long without moving.
Old Mar 9, 2009 | 02:11 PM
RSandy's Avatar
RSandy
due to the big time frame concerned here, maybe on its initial rebuild, the bottom end in question had a crank grind, and then subsequently had the incorrect sized bearings fitted? just an idea
KW-rscos
11
Aug 31, 2015 01:51 PM
mrknifey
Aug 30, 2015 11:48 AM
IAN RS2k
Aug 18, 2015 07:51 PM
john_3.0s
Aug 15, 2015 07:44 AM
