How tight should a cosworth cambelt be?
Old Mar 8, 2009 | 11:07 PM
SelbyRST's Avatar
SelbyRST
4x4 SAFF
Default How tight should a cosworth cambelt be?
Iv just bought a 4x4 saff and looking for a little bit of adivse.
I took the cambelt cover off today and when you press down on the top of the cambelt it goes up and down quite abit as if its not that tight, im assuming it should be quite tight? And when the engine is running you can see it going up and down, is this correct or not as i think? If you understand how iv expplained it!
Hope someone can help, thanks
Old Mar 8, 2009 | 11:10 PM
mechanic28's Avatar
mechanic28
they are quite loose when cold mate!I done mine to tight and it eventually knocked out my front camshaft bearing as a general rule get hold of the belt (oppisite the tensioner)and you should be able to turn the belt 90% fairly easy any more its prob to loose
Old Mar 8, 2009 | 11:11 PM
J1mbo's Avatar
J1mbo
B1mbo
you should be able to twist the belt 90degrees
between the inlet pulley and crank pulley, half way between the two, twist it,
if it is too loose, twists more that 90 then it may be good to undo the tensioner belt, check the tensioner and then re tension the belt,
hope that makes sense
Old Mar 8, 2009 | 11:16 PM
SelbyRST's Avatar
SelbyRST
4x4 SAFF
It wqas from cold yeah, hope fully ill be able to get it into nms this week, its been run in and that on an engine dyno 1200 miles ago, but just want it checking over for peace of mind reallly.
Thanks for your help.
One more question if you dont mind, where the turbo oil feed comes from the block a slight bit of oil is coming out, and aso the pipe that goes to the breather that comes out on the left hand sidenear the back of the block. Will this most likely just be this hose needs the jubille tightening? Its a brand new 200 block so it wont be anyything wrong with the block
Its quite a step coming from an rs turbo to a cos, there alot more complicated lol
Old Mar 8, 2009 | 11:18 PM
mechanic28's Avatar
mechanic28
plumbing tape is all you need chap put some on the threads should sort it
Old Mar 8, 2009 | 11:19 PM
SelbyRST's Avatar
SelbyRST
4x4 SAFF
Thats alright then as i am a plumber lol. Thanks for your help.
Old Mar 8, 2009 | 11:22 PM
mechanic28's Avatar
mechanic28
no probs chap
Old Mar 9, 2009 | 03:56 PM
The last thing you want is this coming off or jumping teeth.
Old Mar 9, 2009 | 04:10 PM
cozmeister's Avatar
cozmeister
More boost Igor!
90 degrees, not 90 percent
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
