BIG spec saff breaking..RELISTED PARTS AND LOWER PRICES
Mar 4, 2009 | 07:15 PM
all parts plus postage, or not if collected!
i dont sell shit, photos will be supplied of all bits before i sell anything!
Most of this stuff is less than 1000miles old.
T4- 102mm air filter hose, £45
Stack oil temp gauge kit £40
Mongoose 4" tail exhaust 4x4, modified and heat wrapped front pipe for 2wd manifold MINT £125
cam belt tensioner and nut as new £20
full 4x4 front cv boot kit, 4 boots all clips and grease, brand new never used, £20
a/s bufty screw type oil cap, stainless, needs new o ring hence £15
Cossie iscv, good order £40
4x4 cossie vibratech engine mounts , mint £60 the pair
4x4 steering rack, new track rod ends £45
+ PRIVATE PLATE C9SSV £300
IF YOU WANT PARTS< STICK YOUR NAME AND THE PART BELOW AND I WILL ADD YOUR NAME TO THEM!
Mar 4, 2009 | 07:22 PM
why ???? if you do mate which i hope you dont i will have:
quaife pulley's
044
Mar 4, 2009 | 07:25 PM
I will have the rear brakes (300m discs and brackets) please James
Steve.
Mar 4, 2009 | 07:26 PM
Ill have that....what comes with it?
washer bottle and the 2 pumps ?
the outside rear door plastic quarter peices, the bit that normally has the sapphire badge on them ?
Matt
Mar 4, 2009 | 07:29 PM
is the wideband a complet kit ready to fit?
if so i would be interested in that
Mar 4, 2009 | 07:30 PM
Quote:
Originally Posted by
Rs500 Registrar
Stack gauges please
Sorry Paul, I already reserved these via PM as soon as the ad was placed.
Mar 4, 2009 | 07:31 PM
lawnsy wideband kit as above....
westus1
yes ready to go
Mar 4, 2009 | 07:33 PM
markyd3
well then do as he asked and put your name down on the post with the parts you want
Is the T4 roller bearing James
Steve
Mar 4, 2009 | 07:34 PM
Moonstone Steve
Steve
no completly std, kev sharps one of his car, little use, it really is a minter
Mar 4, 2009 | 07:35 PM
what exhaust is on it and condition?
Mar 4, 2009 | 07:37 PM
Rs500 Registrar
Sorry mate yes that was my fault... I was in such a hurry to reserve them i just sent the PM and forgot to add it on here!!
Hope ive not pissed you off too much !!
Markyd3 - Stack Gauges
lawnsy
mint mongoose 4"tail, modified front pipe for 2wd manifold
150
Mar 4, 2009 | 07:39 PM
markyd3
Not at all mate , first come first served
lawnsy
boooo i asked 1st
Mar 4, 2009 | 07:40 PM
Possibly the RS500 intercooler aswell for me - PM sent
mmmmm just realised its 4wd..... typical...
Mar 4, 2009 | 07:41 PM
westus1
boooo i asked 1st
Look 9 posts above yours....
Mar 4, 2009 | 07:43 PM
Does the coil pack not need the driver to work?
Mar 4, 2009 | 07:45 PM
Captain500rs
yes a driver in the ecu
Mar 4, 2009 | 07:51 PM
T4 and cams put me down 1st refusal please
Mar 4, 2009 | 07:56 PM
lawnsy
Should still fit though mate!?
Paul, is your PM inbox empty yet ??
tried to PM you the other day lol
also sorry to post hijack
Matt
Rs500 Registrar
Mar 4, 2009 | 07:58 PM
RS500 intercooler for me aswell
Mar 4, 2009 | 07:59 PM
I can collect the brakes in April James
Steve
Mar 4, 2009 | 08:03 PM
I'll have the bailey mirror image tank please.
Cheers mate.
Mar 4, 2009 | 08:06 PM
some pics
Mar 4, 2009 | 08:08 PM
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Mar 4, 2009 | 08:13 PM
Dont do it
but il have the Swedish plenum
Mar 4, 2009 | 08:23 PM
Turbo damper?? Or will it come with the turbo anyway
Mar 4, 2009 | 08:27 PM
gaz coilovers mate plzzzzzzz and why are you stripping it!!??
Mar 4, 2009 | 08:28 PM
4x4 rear calipers (refurbed) £50 anychance of a picture>???
might be interested in the shell... rebuilding mine at moment and it gonna need a lot of work done to shell.. that one looks pretty good...any bad bits?
Mar 4, 2009 | 08:30 PM
lawnsy
show me where this says anything about wideband?
ooooooooo damn f**king bas*ard sh*t yours is a 4wd?? forget that mate sorry!
Mar 4, 2009 | 08:31 PM
lawnsy
if you mean this post
look 2 above that
as i said, i asked 1st
Mar 4, 2009 | 08:36 PM
westus1
look 2 above that
yip you did but i asked 9 posts before that.....
