How much water does the rst hold?
Mar 3, 2009 | 01:02 PM
Iv just had the turbo off my s1 and im going to fill it up with water how much does it hold as i want to put the correct 50/50 water and anti freeze in. cheeRS
Mar 3, 2009 | 05:00 PM
My s2 holds around the 4 litre mark iirc, put a couple of litres of anti freeze in, that should be plenty mate!
Mar 3, 2009 | 07:19 PM
its 7.9 litres from empty to the header tank on MAX.
Mar 3, 2009 | 07:25 PM
Bloody hell! Don't remember putting that much in lol, i guess unless it's the first time after a rebuild it won't be fully empty though.
Mar 3, 2009 | 07:31 PM
Yeah the 7.9 is from bone dry so more like 4 or so. Make sure you mix the antifreeze with the water before you put it in, i put some in neat once for it to mix in the engine and shagged the seal in the waterpump staight off
Mar 3, 2009 | 07:41 PM
Thought i normally put about 4 in when i'm changing the water for a freshen up or whatever......oops i never bother premixing it as such, though i've never had a problem doing this.
Mar 3, 2009 | 07:49 PM
Think my pump may have be allergic to antifreeze
Mar 3, 2009 | 08:24 PM
Lol sounds like it might have been yeah....you sure it was antifreeze you put in lol!
Mar 3, 2009 | 08:53 PM
Quote:
Originally Posted by
kidsRS
Depends how rusty your battery tray, fuse box, and sunroof are?
Mar 4, 2009 | 12:06 PM
Karlos it wont get higher than the bottom of the set lol. Ill make a mix in a bit and fill her up.
Mar 4, 2009 | 12:08 PM
Karlos G
Its a RST so very!
Mar 4, 2009 | 01:08 PM
Karlos G
exactly wot i was gonna say, can hold plenty in the spare wheel space when the tailgate rusts aswell
Mar 4, 2009 | 02:31 PM
kidsRS
RS 5tu
Its a RST so very!
Chris69
Gotta love our RS's
A.t.p
Oct 23, 2015 07:54 PM
Mark RS
Oct 12, 2015 06:01 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
antifreeze ,
block ,
coolant ,
engine ,
escort ,
focus ,
ford ,
hold ,
litres ,
put ,
rs ,
rst ,
take ,
turbo ,
waater ,
water
