What gives first when raising the Rev limiter?
Old Mar 2, 2009 | 10:10 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Default What gives first when raising the Rev limiter?
Is it the big end bolts, or valve float?
Thinking about raising mine to 7200rpm just before my next setup and have ARP rod bolts fitted and double valve springs.
Anyone know anything or have any experiences?
Thanks
Old Mar 2, 2009 | 10:18 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
just the engine in general,lol,why raise it,is the power up there?
Old Mar 2, 2009 | 10:23 PM
boothy's Avatar
boothy
BANG and its gone......
Old Mar 2, 2009 | 10:32 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
No point, you'll not be making usable power up there.
You'll probably run into valve-train issue's, such as valve float, or perhaps a lifter will shit itself.
Old Mar 2, 2009 | 10:33 PM
Christian and Beccy
#1 in Spelling Club
....or maybe you'll drop an exhaust valve, if the map is a little off too.
Old Mar 2, 2009 | 10:49 PM
orion_crazy_carl
orion=mini saff
his map?whts his A to Z got to do with it
karlos,went out in jonnies onion last night,cant believe its finally on the road!it looks and sounds the bollox to!
Old Mar 3, 2009 | 02:25 AM
Andy_R's Avatar
Andy_R
As the lads have said if your cars dropping off power before this point then why would you want to rev it that high, your just prolonging the dead zone so to speak.
Sure it sounds good at 7000 RPM sounds better still at 8000rpm and beyond - but in my experience wont last long. I'll not go into failure details on here but we had a few with my builds. Your asking a lot with valves at the size they are likely to be and the weight they are and when you add to that the additional RPM its no surprise that there has to be a limiting factor somewhere.
Your beter looking at maximising your usable power band IMO
Old Mar 3, 2009 | 07:17 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Ok fella's that settles that one then! lol
I just thought with the power band of an RS being as short as it is (3000 -6400rpm) it would be nice to extend that a little, but i'll forget that idea
Oh nice is it all running sweet now? He said it was overfuelling badly the other day, hasnt had it setup yet though has he?
Old Mar 3, 2009 | 08:41 AM
Christian and Beccy
#1 in Spelling Club
Also, revving it beyond where it is making useful power will just generate high temps, resulting in (as I mentioned earlier), damage to exhaust valves etc and/or detonation.
Mine doesn't really need to be revved beyond 7000-7200 and look at that work that has gone into that.
Old Mar 3, 2009 | 09:33 AM
Tim's Avatar
Tim
my new rev limit is 8000 lol but thats just to stop me hitting it lol 7200 is plenty on an old cvh lol and i know all about rippin stuff apart at high revs had loads of bollockings for it lol mind you its well strong up there i just love the sound lmao,
to answer you question the lifters if there hydrolic go first then the valve springs then the big end bolts and last the oil pump surges its tits of then explodes lol
Old Mar 3, 2009 | 10:52 AM
Andy_R's Avatar
Andy_R
Tim N/A CVH's were/are happy enough at 8000rpm Turbo'd ones just dont like living there
Old Mar 3, 2009 | 11:08 AM
B16CVH's Avatar
B16CVH
Dont think the standard rods like living up ther either
Old Mar 3, 2009 | 12:13 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Ok so the general consensus is that it's a big NO to raising the limiter if i want the engine to last any longer than 10mins
I'll leave it as it is!
Old Mar 3, 2009 | 11:29 PM
orion_crazy_carl
orion=mini saff
it was under fueling the penis was low on petrol
Old Mar 4, 2009 | 07:16 AM
Karlos G's Avatar
Karlos G
Balls Deep!
PMSL! Classic!
tankybaby66
Feb 6, 2016 02:24 PM
SMILER258
Sep 28, 2015 09:04 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
