urgent engine help?
Old Mar 1, 2009 | 12:43 PM
smerth54's Avatar
smerth54
Default urgent engine help?
rite i need help ive snapped the bolt that the rocker arm sits on any idea how you get these out and what bolt i would need 2 replace it?
thanks rich
Old Mar 1, 2009 | 05:00 PM
smerth54's Avatar
smerth54
bump
Old Mar 1, 2009 | 05:18 PM
rst in breaking's Avatar
rst in breaking
poss easy out and heat? but dodgy territory as you dont want swarf in you head
Old Mar 1, 2009 | 05:46 PM
Did it snap because it was too tight going in or did you just do the nut too tight ?
If you need to drill, ie not enough left to get hold of, just place rags around area to stop swarf getting places.
If there is enough to get a old nut over I would first try welding a nut on the remains, applying as much heat as you can get away with, as it will help.
Failing that drill and extractor needed, but nut and weld vastly better.
Old Mar 2, 2009 | 12:30 AM
smerth54's Avatar
smerth54
nah cant get a nut on it will have to drill it out i think i done up the valve compresser toll up 2 tight and snapped it. so basically the best option is gettin a new head cos i dont think ill b able 2 get a new one will i.
Old Mar 2, 2009 | 06:29 AM
A machine shop will be be able to rescue this a lot cheaper than a new head.
Old Mar 2, 2009 | 11:56 AM
smerth54's Avatar
smerth54
ok ill look into this then thanks
