cvh in a puma
yes, one guy on pumapeople did. he had shit loads of problems as it was done by Seven Valley.
I see no reason why youd want to go to the hassle of doing custom mounts and looms to fit a really old, limited CVH?? youd be much better off going down a zetec turbo or modern lieghtweight duratec route, especially if you want big power.
does a zetec fit in easy enough?
just got a 1400 one for very little money but weighin up my options as i have a recently rebuilt cvh turbo in the garage
so a heavy iron lump 1.8 or 2.0 with 105/115/130bhp or 136bhp versus an all alloy lump??? if your going to do a NA zetec your better off dropping in a tuned 1.6/1.7 zetec SE from another puma!
A much heavier engine only works if the power well outwieghs the wieght cost.
The 1.8 and 2.0 do chuck out more torque though rather than revs although can be made to rev. Mine should be about 150bhp 150ftlbs torque with the current mods being done to it now hopefully. A 150bhp 1.6 or 1.7 would be about 20 or 30ftlbs down from that. Also why do most of the Si boys chuck 2.0 zetecs in?
Go for it, put the RST cvh in. if you have a good one already you may aswell. its not going to be that hard to fit. Running at a bar boost and breathing better the puma should be a good fun little runabout.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
mk3ste
Oct 17, 2021 10:09 AM
