Focus Blacktop Turbo Engine Package With FRS Gearbox etc.
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Rightio - the other thread was a bit cluttered so let's start afresh!
I bought this package from the chairman of the Ford Focus Owners Club when he broke his car a few years ago, had planned to put it in my old Escort project, but i went chasing bigger numbers and never used it!
It ran in his car for approx 5000 miles after being fully built by Power Engineering back in the Chris Todd era.
Engine Spec:
8.8:1 Compression Ratio
Arrow Steel Con Rods
Mahle Pistons
Std Crank
Cylinder Head Developments Ported Head
Std Valve Size
Power Engineering Turbo Spec Piper Cams
Piper Vernier Pulleys
The engine is still 'dressed' with the following:
Focus 2.0 Zetec Inlet Manifold & Throttle Body
Focus RS Injectors, Fuel Rail & Pressure Regulator
Focus RS Water Pump
Focus ST170 Oil Pump
Focus 2.0 Zetec Alternator
Idle Valve
Starter Motor
Oil Feed Line
Oil Retun Into Sump
Breather Flame Trap
Oil Cooler Modine
Coilpack, Leads & Plugs
Polished Fuel Rail Cover
Polished Lifting Eyes
Polished Oil Filler Cap
Water Temp Sensor
Air Temp Sensor
Coilpack Bracket
Thermostat
Fuel Injector Wiring Loom
Focus RS Gearbox
AP Racing Uprated Clutch
Focus RS Driveshafts
Focus RS Gearlinkages
Looking for £2250 for the complete package.
Engine Spec:
Mahle Pistons
Std Crank
Std Valve Size
Focus RS Water Pump
Idle Valve
Starter Motor
Oil Feed Line
Oil Retun Into Sump
Breather Flame Trap
Oil Cooler Modine
Water Temp Sensor
Air Temp Sensor
Coilpack Bracket
Thermostat
Focus RS Gearbox
Hi mate,
Yes - previous deal fell through!
Hence the starting a new ad
Got your PM pal - would the transmission be of interest?
Wilsfoci
15
Mar 30, 2016 10:26 PM
