Ford wiring plugs
Old Feb 28, 2009 | 05:52 PM
Drewman's Avatar
Drewman
Default Ford wiring plugs
Is it possible to re-wire these?
You know the plugs that are moulded around wiring to clip on to say a temperature sender with the little metal spring clips?
Thanks
Old Feb 28, 2009 | 06:24 PM
dojj's Avatar
dojj
Resident Wrestling Legend
yes, just get the pins out by sticking a skinny screwdriver into them
as long as the plugs are moulded it's a peice of cake
Old Mar 1, 2009 | 09:04 AM
As above but not expensive anyway, and all available new, with new terminals etc.
Old Mar 1, 2009 | 09:24 AM
zetaboostboy522bhp's Avatar
zetaboostboy522bhp
vehicle wiring products mate , have a look at there website they sell new connectors, pins , rubber boots and best of all the special tool to take all sorts of pins out , the best £20 ive spent , hope this helps
Old Mar 1, 2009 | 01:53 PM
The above are ok price wise if you only need a few bits, but others care cheaper but may need account etc.
On a lot of the connectors the pins/terminals can be removed just with a very thin screwdriver.
Old Mar 1, 2009 | 08:38 PM
Drewman's Avatar
Drewman
Great, Ive got a spare from the scrappy just needed to swap it over. I'll give it a go with a skinny. Cheers for the info.
Old Mar 2, 2009 | 11:59 AM
There's two basic multi extractors which do a lot of common pins, reasonably inexpensively, but some others are £100 for a remover for just 1 terminal type.
j.hammond1
30
Oct 31, 2021 05:28 PM
muz
Aug 16, 2015 12:57 PM
Roosie
Aug 15, 2015 08:09 PM
muffster
Aug 11, 2015 05:39 PM
