cosworth misfire cyl 1
Old Feb 27, 2009 | 01:12 PM
madcossy's Avatar
madcossy
Default cosworth misfire cyl 1
can annyone help got an annoying misfire on plug 1 changed all plugs leads cap rotary arm ignition amplifier when i pull plugs out 3 are normal and plug 1 is sooty
Old Feb 27, 2009 | 01:23 PM
grcossie's Avatar
grcossie
Maybe a injector leak. I had the same on my ex Sierra, it was the earth lead to injector, that was unisolated and earth in fuel rail, then it it was open all time. Check wire
Old Feb 27, 2009 | 01:25 PM
ECU Monitor Enthusiast
Temporarily swap the injector plugs with cylinder 2 to set if it comes back alive.
Old Feb 27, 2009 | 01:43 PM
JamesH's Avatar
JamesH
Take injector clip off injector 1 and check both wires are seated in the connector properly
If not then push them home
If they are, then try swapping an injector or an injector plug as per Simon
Old Feb 27, 2009 | 02:02 PM
Swap the spark plug from no1 cyl to no 2 cyl to find out if you have a dodgey spark plug.
Old Feb 27, 2009 | 02:23 PM
LOL, Remove spark plugs from engine first otherwise you may blow the inlet manifold off
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
