S2 strip down
Old Feb 22, 2004 | 04:48 PM
Benn 304R's Avatar
Benn 304R
Default S2 strip down
Ello,
Currently stripping my girlfriends RST as we ahve a new shell to put it all in.
Here are some pics
bodykit off, and this is what was under it lol
the floorpan
bottom of inner rear 1/4
Front end stripped
Inner wings are clean and so is battery tray
Dash and steering rack out
My so called helper
Apart from polishing the shiny bits, she spent the rest of the time mucking about lol
Loom and the rear end to be stripped down this week
Old Feb 22, 2004 | 04:50 PM
Benn 304R's Avatar
Benn 304R
All the rust is on the drivers side
Basically needs a new complete sill, rear 1/4 repair section and rear drivers side floorpan section.
Rest of the car is very good indeed
Old Feb 22, 2004 | 06:20 PM
John Laverick's Avatar
John Laverick
Does look pretty bad
I'm restoring mine at the moment and the drivers side seems to be 50% worse than the passengers which I wasn't expecting
Whats the new shell like you've got hold of?
Old Feb 22, 2004 | 06:51 PM
Benn 304R's Avatar
Benn 304R
not bad, replacing some panels as we want it to be "pucker" and for show use
Old Feb 22, 2004 | 07:34 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Benn, When I first saw the pics I was a bit shocked, but the front of the car is pretty good. What are you going to do with that shell?
Plus, I might have to nick some bits off of it first m8 as a few thigns I wanted weren't available from Ford anymore
Old Feb 22, 2004 | 10:27 PM
John Laverick
It seems strange the difference in condition of Mk4 escorts of similar age looking at all these resto photos.
Mines gone manily on the rear end, especially the outer sills O/S whereas Tonys seams to be based around the battery tray (Mines original and looks like its just rolled out of the factory )
Whereas as this shell seems to be a little bit all over?
Old Feb 23, 2004 | 04:02 PM
Tony Turbo's Avatar
Tony Turbo
Damo and I said this last night. Mine has mainly rotten due to a dodgey replacment tray in the first place, which has leaked water in etc etc, the rest is ok. They start rotting from the factory because of the way they are made.
Old Feb 23, 2004 | 04:11 PM
Benn 304R's Avatar
Benn 304R
What bits ya need Tone?
Old Feb 23, 2004 | 04:13 PM
Chick's Avatar
Chick
Too true TT, there are too many pockets for water to gather in, I have generally found that as long as the car has been cleaned regularly and properly and used regularly rather than sitting in the one place for long periods the body shells are better. My old man bought a D reg Mk4 Combi in 1993 which had 127K miles on it when he bought it and it was mint. Everybody at the time said how 1987 to 1988 was the worst years for Fords rusting. I got my mits on the van in 1996 and it had 185K miles on it without any welding needing done on it until then when it needed a battery tray and the front wing to front panel joins welded, I re sprayed it and tyarted it up a bit and sold it on with 198K miles on the clock. The guy after me kept it for nearly 2 years before the floor went rotten because the guy hadn't fixed the hole next to the fusebox I reckon the amount of rust that a vehicle gets is down solely to the way that the vehicle is treated.
Old Feb 23, 2004 | 04:14 PM
Tony Turbo's Avatar
Tony Turbo
Clips mainly
Old Feb 23, 2004 | 04:18 PM
Benn 304R's Avatar
Benn 304R
ive broken a few
Old Feb 23, 2004 | 04:28 PM
Chick's Avatar
Chick
I've got some, depends on which ones your after m8 give me a shout and I'll see what I can find in ma boxes!
Old Feb 24, 2004 | 06:33 AM
adamS2RST's Avatar
adamS2RST
Damn Escorts, I iknow what you mean John, they do go in slightly different places, although it is the key places like batt try, wheel arches, sunroof etc which get hit the worst. It is all worth doing now because it only get's worse!
Old Feb 24, 2004 | 07:38 AM
its welding time
Old Feb 24, 2004 | 09:35 AM
Adam_BlackRS's Avatar
Adam_BlackRS
Ex Ford Man
Looks like you haven't done much since i last asked you
Old Feb 24, 2004 | 09:57 AM
Benn 304R's Avatar
Benn 304R
i havent lol
By the end of this week it will be fully stripped and ready to sell to anyone that wants it
Old Feb 24, 2004 | 09:24 PM
Damo V's Avatar
Damo V
And to think there are people out there who would say and believe, a car havng an accident damaged R1/4 panel replaced makes no difference whatsoever , best they have a litttle look at these pics I think...... ... that shel would be proper clean otherwise....
Old Feb 25, 2004 | 10:07 PM
good work mate
Old Feb 25, 2004 | 10:13 PM
Benn 304R's Avatar
Benn 304R
Damo, it doesnt look like its been done properly either
Old Mar 4, 2004 | 11:37 PM
Tony Turbo's Avatar
Tony Turbo
Take some more pics m8
Old Mar 5, 2004 | 03:23 AM
RobS's Avatar
RobS
good luck with it m8, keep u busy 4 a bit
Old Mar 5, 2004 | 06:19 PM
hows it going
Old Mar 12, 2004 | 09:52 AM
Tony Turbo's Avatar
Tony Turbo
What have you been doing these 2 weeks?
Old Mar 18, 2004 | 11:47 PM
up ,whats going on mate ,hows it going
Old Mar 19, 2004 | 09:10 AM
AlexF's Avatar
AlexF
Why not just weld it up... theres hardly anything to do on it
Old Mar 19, 2004 | 12:30 PM
BillyCabrio's Avatar
BillyCabrio
Whats the hold up Benny?
Old Mar 23, 2004 | 02:14 PM
EssexBoyRacer's Avatar
EssexBoyRacer
got all this to come
Old Mar 25, 2004 | 12:35 AM
Tony Turbo's Avatar
Tony Turbo
Start your own one
Old Mar 25, 2004 | 09:20 AM
EssexBoyRacer
lol, will do when I've done something! lol
Old Mar 25, 2004 | 02:28 PM
Benn 304R's Avatar
Benn 304R
Right, everything is stripped out now, gonig down the unit at the weekend to sort out all the bits for powder coating etc etc.
Also take some more pics of the old shell and bits that are to be sold.
Still trying to sort out a garage to spray the new shell
Old Mar 25, 2004 | 03:00 PM
Tony Turbo's Avatar
Tony Turbo
Someone must want to do it mate, can't be that bad
Old Mar 31, 2004 | 03:38 PM
Benn 304R's Avatar
Benn 304R
heres some pics of the shell that we stripped.
Heres the nice rusty bits lol
This is that rear 1/4 I was on about,
passenger side rear arch not as bad,
There ya go, thats as far as we have got
Old Mar 31, 2004 | 05:32 PM
Tony Turbo's Avatar
Tony Turbo
Not THAT bad then? Bit hard to tell really, what with the pictures being so fucking big
Sorted out someone to do it yet?
Old Mar 31, 2004 | 06:26 PM
Benn 304R's Avatar
Benn 304R
Not yet
Old Mar 31, 2004 | 06:31 PM
Adam_BlackRS
Ex Ford Man
bout time mate
Old Apr 5, 2004 | 09:51 PM
deleted's Avatar
deleted
From: learnin to build a yb lump properly in dennis's garage
hows it coming along?
Old Apr 6, 2004 | 07:47 AM
Is it me or does that shell look pretty good? I would have thought some
skilled local repairs where needed would have been easier than a
complete reshell?? The front especially the inner wing areas and cross
members all look great. Even the chassis sections that kick over the rear
wheels look good. Surely some nicely fitted new arches and localised
repair plates is the way to go?
Sorry if I'm wrong, just going by what I can see and what I have had
experience restoring before.
Wolfy
Old Apr 6, 2004 | 08:16 AM
Damo V's Avatar
Damo V
DreamWolf, yeah mate, it isnt too bad you are right.... The shell is for sale if you fancy a bash
Old Apr 6, 2004 | 03:42 PM
Benn 304R's Avatar
Benn 304R
Dreamwolf, get your arse into the rs turbo for sale section and name your price
Old Apr 6, 2004 | 04:23 PM
AlexF's Avatar
AlexF
do you acpet payment in kind Benn???
