Buying a 205 Gti
Old Feb 25, 2009 | 01:34 PM
PaulT's Avatar
PaulT
Default Buying a 205 Gti
Where are the rust hotspots on these cars and anything else that should be looked for?
Cheers PaulT
Old Feb 25, 2009 | 01:42 PM
Spiky's Avatar
Spiky
front inner wings
bottom corner where the door meets te sheel
top as per above
boot floor
by headlights
they should have much rust as they are galvanised,
check the rear beam isnt seized, very commen
if it feels flat, it's probably a worn out afm
rear brakes are rubbish
Old Feb 25, 2009 | 01:49 PM
TurboShed's Avatar
TurboShed
Cossiemodo
Originally Posted by Spiky
...they should have much rust as they are galvanised...
Wow I never new that. Always wondered why the one I had was totally utterly rust-free! Was an E plate and I had it in about 1998 so wasn't a new car even then by any means.
Old Feb 25, 2009 | 01:56 PM
Spiky's Avatar
Spiky
when i stripped mine the sound deadening was soaking wet, wiped the floor and it was all shiney
Old Feb 25, 2009 | 02:01 PM
Ed1's Avatar
Ed1
Peugeot's are the best!
My mechanics 205 gti6'd track beast!
He like peugeots too, this is his drive
Old Feb 25, 2009 | 02:09 PM
Spiky's Avatar
Spiky
SEEN the 205 on the pug forums
nice looking car
Old Feb 25, 2009 | 02:14 PM
Less.'s Avatar
Less.
having a mid life crisis
Blimey he likes his pugs
Old Feb 25, 2009 | 02:24 PM
Ed1's Avatar
Ed1
Hes got more round the back and down his workshop! hes got a 306 rallye with just over 200 miles on it on a W plate!
Old Feb 25, 2009 | 02:33 PM
TIFF's Avatar
TIFF
Chasing Radders
Cant beat a good 205...
Here is a few of my Norris Motorsport built/ AB Motorsport maintained 205 Mi16 track weapon
Just dug the spec of the car out of my folders and it was a very well spec'd car
Mi16 powered 205 1.9 GTi
running 12:1 compression,
NMS ported head,
270deg fast road cams,
Fully live mapped with 7600rpm limit,
Tubular exhaust manifold and 2 1/4" 1 piece S/S system custom made at AB Motorsport
Brand New Mocal 13 Row Oil Cooler.
Brand New 283mm 206 GTi 180 Front brake set-up
Brand New Pugsport Baffled Sump
Brand New uprated oil pressure spring
Brand New rear calipers
Brand New FULLY rebuilt rear beam including Brand New pins and tube by AB Motorsport with Group A bushes and lowered, 306 arms for camber
Apex Suspention
309 GTi front suspention set-up for camber
Drilled rear discs
Goodyear Eagle F1's all round
6 Point welded in Saftey Devices Roll Cage
Willans 5 point Harnesses,
850kg with 180bhp
A spare set of 1.9 alloys with slicks fitted
New diesel starter motor
Old Feb 25, 2009 | 05:33 PM
PaulT's Avatar
PaulT
Its a J plate 1.6 in grey going to have a look tomorrow, seen a few quick ones going round curborough will post pics if i have it.
Cheers for the pointers PaulT
Old Feb 25, 2009 | 05:52 PM
CraigoScott's Avatar
CraigoScott
ive got one and i love it, if it idles funny then dont worry, they all seem too at some stage! as said, check rear beam, knocking is never a good thing, neither is squeeking!
if it has rust then there shouldnt be much, if it has lots then that suggests its had a shunt/repair at some stage!
Old Feb 25, 2009 | 06:23 PM
Spiky's Avatar
Spiky
craigscott, any movement at all is a bonus sometimes
Old Feb 25, 2009 | 07:10 PM
big_wig_074's Avatar
big_wig_074
oh,and dont worry if the temp looks a little high on the gauge!its done in degrees rather than cold to hot,mine always sat at about 3/4 when warm which was apparently right,unlike every other car that likes to sit half way up.
Old Feb 25, 2009 | 07:49 PM
Spiky's Avatar
Spiky
well mine must be an odd one
run half way with 1.9 engine even on track
run's less than half with gti6 engine
i have put a new nissens rad on mine mind, so that probably is it
tankybaby66
Feb 6, 2016 02:24 PM
Fil
Sep 30, 2015 12:08 PM
muz
Sep 30, 2015 08:29 AM
Nick 172 Sport
Sep 28, 2015 07:21 PM
