hi-spec big disk kit on a 4x4 saff HELP!
Old Feb 24, 2009 | 07:49 PM
Twellsie's Avatar
Twellsie
Default hi-spec big disk kit on a 4x4 saff HELP!
trid to fit the new disks at the weekend but ran into a couple of problems, bought them second hand so only got the bell, rotors and brackets, no instuctions or bolts etc
first problem the disks dont fit in the calipers as they are too wide and touch on the carrier part of the caliper
second problem, the caliper overlaps the bolts that hold the brackets on, was it some kind of special bolt that goes in it so the caliper can sit flush?
anyone shead any light on this?
Old Feb 24, 2009 | 07:54 PM
RSandy's Avatar
RSandy
the hi spec big disc kit on my S2 (yes im aware its a different car) came with a variety of spacers and such, so that the carrier sits correct distance away from bracket etc, plus a couple of bolts with internal allen key heads so that it can clear a stndard bolt in close proximity
maybe could be a similar situation here?
Old Feb 24, 2009 | 08:00 PM
Paul_RS's Avatar
Paul_RS
This a front or rear kit matey?
Old Feb 24, 2009 | 08:02 PM
Tev's Avatar
Tev
come round mine i will make them fit, im quite handy with the angle grinder now,
Old Feb 24, 2009 | 08:03 PM
Twellsie's Avatar
Twellsie
front
Old Feb 24, 2009 | 08:04 PM
jay man's Avatar
jay man
brackets possibly are 2wd
Old Feb 24, 2009 | 08:08 PM
Twellsie's Avatar
Twellsie
they have got 4x4 COS BDK stamped on them
Old Feb 24, 2009 | 08:11 PM
slowpoke's Avatar
slowpoke
i had this kit on my saph,
you have to widen your caliper with a dremel or a file so they slot in
if i remember rightly you have to tap the lower mounting hole on the wheel hub
hope this helps...........Matt
Old Feb 24, 2009 | 08:13 PM
Twellsie's Avatar
Twellsie
cool, i was planning on attacking the caliper with an angle grinder, lol
did you need to use any washers to space the caliper away from the bracket to allow for the bolt it covers?
edit
ah that make sense, you tap the mounting hole on the hub and put the bolt in from the opposite direction maybe
Old Feb 24, 2009 | 09:04 PM
slowpoke's Avatar
slowpoke
yep thats the one,
the bolt goes in the other way around
im sure its the bottom mounting hole you tap out
matt
Old Feb 24, 2009 | 09:19 PM
Twellsie's Avatar
Twellsie
yep thats the one,
matt
i have just been to the garage to get the brackets, the hole that fouls is bigger than the others, so i am guessing that you tap the hub to m12 and put the bolt in from the other direction, as you have said
Old Feb 24, 2009 | 10:36 PM
slowpoke's Avatar
slowpoke
exactomundo
jonfoc
16
Sep 11, 2018 05:35 PM
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
