Whats the main GOLF forum?
150 suffers fucked cams
130 is rated far better and better driver car
this came from a vw specialist is edinburgh......... he had a 150 in stock with the engine in bits with rattly cams very common
130 and re-map it
130 and re-map it
As Micky said www.uk-mkivs.net is your one.
And as everyone else said, the PD130 sounds like the one to go for, I LOVE my mapped 130 Bora, loads of torque and mega fuel economy. Cant rate the car enough.
I have a 150 running 220hp and its got 127k so far no cam issues. FYI the cam fails due to the tappets failing.
From what I've read VW changed/modified the tappets on the later models late 52 plate onwards should be fine.
They are great cars - the engines on the 130 and 150 are pretty much the same. However for power the 150 is much better comes with a FMIC and bigger turbo as standard. The 150 remapped will make around 190hp from just a remap.
We have a 130 mk4 tdi 6 speed, mapped and Audi TT brakes fitted, makes for a cracking daily driver.
Another good site is www.edition38.com
