2 wd cosworth 324mm brembo 4 pot brake kit(lower price and more pictures added 14/3/
i hav for sale a cosworth 2 wd brembo 4 pot brake caliper kit.
the calipers are off a alfa gtv. (same as focus rs) they hav been stripped then blast cleaned back to bare ally with special care not to blast down the pots using blanking caps.they hav been modified to fit the cos 2wd hub carrier then repainted in high resistant black paint then new heatproof decals hav been applyed then finished with heat resistant laquer. the seals hav been checked and replaced if neccesary.the calipers come with brand new special 16mm 6082 t6 grade alloy adaptor brackets and 303.grade stainless steel spacers plus new bolts and washers designed by myself and cnc machined at metmachex engineering in derbyshire.the discs are brand new focus rs 324mm ebc dimpled and grooved sports.this kit is an excellent improvment over the standard set up,proper stopping power.kit does nt come with pads i would recomend the use of ebc redstuff pads to feel the full benefit of this set up.also unlike the focus rs calipers ,the original brake line fitments are the same as standard cosworth so there is no need to hav special hoses made up.also this set up will require 17"+ wheels. i m asking £450 ono for this kit.
i will be posting pictures in the next few days please pm me with any questions
thanks
jack
here is a picture of the same set up in silver on my 2wd sapphire.
thanks
jack
Aug 14, 2015 07:29 AM
track.focus'd
Aug 12, 2015 05:53 PM
