Small turbo ecu's?
Old Feb 23, 2009 | 10:01 AM
alo's Avatar
alo
Default Small turbo ecu's?
What Ecu did the st escos come with?L8 or p8
Cheers Aaron
Old Feb 23, 2009 | 10:04 AM
paul16v's Avatar
paul16v
Monte 087
Niether, the small turbos diddnt use bosch management.
Old Feb 23, 2009 | 10:12 AM
alo's Avatar
alo
what does it run do you know? ford management of some kind?
Old Feb 23, 2009 | 10:15 AM
MannheimAlex's Avatar
MannheimAlex
Yep, it runs Fords own managmanet. Think EECIV or so?!?
Old Feb 23, 2009 | 10:19 AM
alo's Avatar
alo
Are they any good or do people get rid?
Old Feb 23, 2009 | 10:50 AM
MannheimAlex
They are good up to 300bhp. After that would be better to change for the weber/marelli stuff
Old Feb 23, 2009 | 12:01 PM
ECOS95's Avatar
ECOS95
Stu @ MSD is working on a conversion that gives more power & retains the Ford ECU. Trouble is its not ready yet unfortunately.
Old Feb 23, 2009 | 12:38 PM
sailorbob's Avatar
sailorbob
The ST runs eec-iv management, it's a far superior ecu to the Weber Marelli ecu.
Old Feb 24, 2009 | 07:31 PM
alo's Avatar
alo
why is this sailorbob?
Old Feb 24, 2009 | 07:50 PM
The Youth.'s Avatar
The Youth.
progress, the cossie ecu can be well over 20 years old it's like comparing a modern pc with an old spectrum 48k!!
steve
Old Feb 24, 2009 | 08:00 PM
alo's Avatar
alo
Do they fit on any cossie loom? Or do they have a completly different one?
If there that good why do they need changing after 300bhp.
I need to know as I have one at hand but is it any good for my application.
Do they run a coil pack anti lag etc?
I'm running low comps
greys
gt35
reprofiled kent cams and verniers
So should be well over 400bhp...
Old Feb 25, 2009 | 09:27 AM
sailorbob's Avatar
sailorbob
The eec-iv loom is completely different to the Weber Marelli loom. They do not need changing after 300 bhp, it's simply that until Motorsports Development undertook developing their conversion no one else bothered due to the complexity of doing so compared with using a Weber ecu. They run wasted spark as standard, I haven't heard of anti-lag on them though. TBH, if you already are running P8 then it's probably is not worth you converting because all your sensors and actuators would need changing too.
Old Mar 6, 2009 | 02:03 PM
Escort1.8si's Avatar
Escort1.8si
im running megasquirt 2 on original engine loom, i removed the eeciv enginge managment module and put in an adaptor board instead witch fit in the original case, all original sensors are used and its quite stright forward. Costed me around 400£ included a wide band lambda.
Old Mar 9, 2009 | 03:49 AM
CRAIG HAYTER's Avatar
CRAIG HAYTER
Question
so if iam getting this right you used a megasquirt mapable ecu and your running you st escos on it?what turbo and injectors etc etc ar you using?and most of all would that not devalue your car?;roll:iam really intrestd as i was thinking of useing a megasquirt on my st escos aswell
Old Mar 9, 2009 | 11:24 AM
STUCOS's Avatar
STUCOS
Craig if your not going to used a ford ecu,go for gotech pro,much better than that garden shed poooooooooo
Old Mar 9, 2009 | 11:32 AM
sailorbob's Avatar
sailorbob
If you are thinking of going the DIY tuning route then there's the Moates QuarterHorse combined emulator and datalogger available for the eec management now http://www.moates.net/product_info.p...roducts_id=199
Old Mar 18, 2009 | 07:48 PM
CRAIG HAYTER
i am just sticking with a small turbo wait to see what MSD do and get a sapphire cossie for running about in during the wk or a r1
big_Rad
Sep 15, 2017 09:36 AM
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
Cosnada
Aug 27, 2015 09:15 AM
IAN RS2k
Aug 18, 2015 07:51 PM
