oil for my rs turbo??
hi there i am planning on doing an oil change on my rs turbo and was wondering what oil is the best to put back in
thanks and could you specify if its synthetic or part
has to be fully synthetic
personally i use silkolene pros 5w 40 as recomended by oilman
but mobil one motorsport 15w 50 is also used by alot of erst owners and ive used it in the past too
if you really want to find out whats best for your spec then register on www.opieoils.co.uk and tell him your spec and he will tell you whats best for your engine
15/50 or 10/50 Fully Synth 3 Ester Oil is the only way to go!
When I changed from a '40' to a '50' it made a 8-10psi oil pressure difference at 85degree's, as I have said before turbo charged engines have a lot higher oil temps than NA engines and so the oil will be thinner hence the need for a higher viscosity oil to maintain the correct pressure and lubricaiton, oil that is too thin will accelerate engine wear at a very fast rate!
The 'w' or Winter rating is pretty much unimportant in this country as we rarely see ambient temps below -10degrees so 5w, 10w, 15w it's all ok.
big_Rad
Sep 15, 2017 09:36 AM
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
