Anti roll bar
Old Feb 21, 2009 | 12:26 PM
boothy's Avatar
boothy
Default Anti roll bar
can you fit the series 1 anti roll bar on the back of the s2??
Old Feb 22, 2009 | 11:01 PM
boothy's Avatar
boothy
Old Feb 23, 2009 | 11:41 AM
B16CVH's Avatar
B16CVH
I think so but you would need the S2 bushes as the roll bar is thicker if i remember right???
Old Feb 23, 2009 | 11:56 AM
boothy's Avatar
boothy
cheers so it can be done, would it be worth doing though...
Old Feb 23, 2009 | 11:59 AM
B16CVH's Avatar
B16CVH
Hmm....its debatable really, surley it would help but you have the hassle of fitting it, if i remember righlty i had to take the fuel tank off or at least drop it down
If you were running coilovers you wouldnt need it.
Old Feb 23, 2009 | 02:50 PM
boothy's Avatar
boothy
im after coilovers at the min mate, just want it to be a stiff as poss....
Old Feb 23, 2009 | 03:54 PM
JesseT's Avatar
JesseT
The S2 bar is stiffer than the S1 bar.
Old Feb 23, 2009 | 04:01 PM
B16CVH's Avatar
B16CVH
I would leave the rollbar then if you are going to go coilovers, will save you the hassle. Go for a fully adjustable setup with the coilies, they work a treat!
Old Feb 23, 2009 | 05:20 PM
kidsRS's Avatar
kidsRS
"Ill check the stock"
She feeling a bit boaty rob?
Old Feb 23, 2009 | 07:26 PM
boothy's Avatar
boothy
yes mate a bit slack to say the least clive
boeb
Jan 9, 2020 05:11 AM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
Mikersturbo
Sep 27, 2015 07:43 PM
