SIERRA COSSIE AUX WARNING (LIGHT FAILURE) DISPLAY
MINES NOT WORKING, NOT TELLING ME ANYTHING LIKE WHEN DOORS ARE OPEN OR LIGHT FAILURE
EVEN THE LOW FUEL & WASHER BOTTLE LIGHTS NOT WORKING?? ARE THESE CONECTED??
HAVE I LOST A MAJOR FEED OR DO YOU RECKON THE UNIT ITSELF IS BUSTED?
DOES'NT LIGHT UP WHEN IGNITION IS TURNED ON EITHER
P.S. IVE SWAPPED THE CONTROL MODULE FOR IT (FROM DRIVERS FOOTWELL) WITH THE ONE ON MY XR4X4 & STILL THE SAME.
THANKS IN ADVANCE
PHIL
EVEN THE LOW FUEL & WASHER BOTTLE LIGHTS NOT WORKING?? ARE THESE CONECTED??HAVE I LOST A MAJOR FEED OR DO YOU RECKON THE UNIT ITSELF IS BUSTED?
THANKS IN ADVANCE
PHIL
sorry i didnt read you already swapped it, however i can tell you that the fuel light and washer light do come off that unit I dont know why just ford in there infinate wisdom i guess, have you tried the basics like the fuse? Im not trying to say your stupid but we can all miss the simple things.
